precision turbo identification
Re: precision turbo identification
Precision marks the compressor outlet (goes to the intercooler) with the wheel sizes.
Fairclough
I just got off the phone with Precision, and the guy told me the number on the outlet of the compressor housing is the a/r so now I know I have .85 a/r on the turbine housing, and .60 a/r on the compressor housing, but I still have to take apart the turbo and measure the wheel to know what size turbo i have! Precision can kiss my as# I'm putting my 35r on asap.
JAY
Model:
-TD06-17C
Compressor wheel
-48 mm / 68 mm
Turbine wheel
-55.3 mm / 65 mm
Turbine Houing
-8cm(A/R : 0.57)
-T3 Inlet Flange
-Internal Gate
6cm2 = 0.41 A/R
7cm2 = 0.49 A/R
8cm2 = 0.57 A/R
9cm2 = 0.65 A/R
10cm2 = 0.73 A/R
11cm2 = 0.81 A/R
12cm2 = 0.89 A/R
14cm2 = 0.97 A R
15cm2 = 1.05 A/R
16cm2 = 1.13 A/R
17cm2 = 1.29 A/R
19cm2 = 1.37 A/R
Look on the outlet as I mentioned, they used to at least mark the wheel size on their. I know mine is.
Fairclough
I looked inside the outlet, it is .60
when I called precision they said that number is just the A/R
Damian
Thats how everyone is though, even with that Garrett GT35. They have more than one option for turbine, and exhaust housings. They also have different compressor housing designs as well.
Fairclough
No, it doesn't have external markings!
Just to let you guys know, I've had 7 turbo motorcycles, and 11 turbo cars, I'm just not used to precision, I usually stick with garrett.
e95 Ty
It's not the end of the world. Take the compressor housing off and measure the wheel then.
Should be a piece of cake for you seeing as you've had so much experience with turbo's..:tup:
