Priming Motor
socalblue
Since my trucks been sitting for a while now I figured Id play it safe and prime the motor before firing it up. Can this be done without removing the upper intake? Accd. to Chiltons you need to remove it?
It's been sitting now for about two months, is it safe to start without priming it? I really want to fire this boy up but this is pretty crucial so I figured I should.
MikeRenz
not stock
Re: Priming Motor
how long has it been sitting? you could always just disconnect your coil and injector harness and crank it till you see some oil pressure on your gauge.
TYHOGG
Re: Priming Motor
2 months shouldn't be long enough to worry about anything. The valve train might clatter for a second before the lifters fill back up. At idle it won't cause any damage.
socalblue
Re: Priming Motor
Just what I wanted to hear, thanks.
For reference though, what would be the max. sit time before priming is a must?
TYHOGG
Re: Priming Motor
MikeRenz said:
2months and 1 day
LOL, Ass.
I'm not sure, its usally the gas that goes bad after a while. It will start to seperate in the tank with out some kind of stabilizer.
