Programmer question (easy one for the gurus)
myclone
I pulled the following statement.....
"Some other tidbits -
Unless you have started with a 3 bar map sensor chip program, or made the changes in the code yourself, you will not be able to make a 2 bar chip into a 3 bar chip using Promgrammer"
From this site...
http://www.chitownsyty.com/bg/chipping.htm
Could someone take a minute to give a chip noob the laymans explanation as to why this cant be done using Programmer?
TIA
smeagol
There is an important section of code changed in the chip to run a 3 bar map sensor. Promgrammer only changes the calibration tables & constants, there is a LOT more 'stuff' in the chip, which is the actual software used to run the ECM. That is the code, and you cannot change it in Promgrammer.
We tried several times to go through and change only calibration tables & constants.. to rescale them for 3 bar. Always had problems. Once you disassemble the code and understand it a bit, you see why. I made the change in the code and almost instantly it worked. I still had to rescale about a zillion things in the calibration tables, but the important change was made in the code.
myclone
Thanks for the info Brian.
Sorry for the "simple" questions ppl but thats just the way lumpys learning process works. I pick up tid bits here and there and eventually (hopefully) put em all togeather at some point.
UNIsackV6
0X Never question the guru 0X JK dude you're truck is mad fast already why do you want it to go faster??? :angel:
Ryan
myclone
Simple.. I wanted to go 12.00 on the stock eng and injectors. Thats done so its time to make it as fast as my budget and know how can. I dont have a big budget so its gonna come mostly from know how :wink: . Got a little sump'n sump'n to settle also (ego thing). :wink: :wink:
UNIsackV6
I know exactly why you want to go faster I just wanted to see if I could destract you :wink: So much for that keep on keepin on and I've got a few words for ya Propane Injection...keep your eyes open and your ears peeled :wink:
myclone
Ive been watching the propane stuff but all the discussions have kinda died out (well, least on here and the buick board).
Im all eyes/ears if you got something in the works :wink: 8) Keep us/me posted..
