Question about PCV valves
Does anyone know if you can still get the AC Delco PCV valves, I read in another post that they are discontinued, but some people say they can still get them. Is the part number for them 799C, with an E stamped on the bottom of the PCV valve?
Thanks in advance guys!
jharrison
Re: Question about PCV valves
I recently (about 2 months back) purchased 4 or 6 of these from the local GM dealer, took 2 days to get them in. Everyone else had them listed but for whatever reason couldn't get them in. Oh, and advance auto parts took it upon themselves to change my order from the AC Delco 799C to the Borg Warner PCV220 PCV valve. Completely wrong part. I ended up taking my order to the store for a refund. If you find them stock up. Your part numbers are correct except if I recall correctly some places had them listed as something like CV799 instead of the 799C. Same part still has the E stamped on it.
motomeccanica
Yes they should be still available. I'm a GM partsman, and they show USA stock (I'm in Canada), I ordered some a couple months ago and got hem fine. GM pn# 8995910, AC Delco CV799C as per other post.
Richard Le
Do you happen to know the "new" part number for the PCV rubber elbows? The original part number I have for them is no longer good: GM #15661594
