questions about moates stuff
Ian Turgeon
Cascading Inspiration
looking at this stuff, and just wanted to make sure my brain is working.
will work for us:
adapters:
G1 - stock replacement for use with 27C128, 29C256, 27SF512
G3 - switchable device, can use 27C128, 29C256, 27SF512, 29F040
chips:
27C128 - stock ( i believe this requires a uv eraser? )
29C256 - will work as electronicly flashable chip
27SF512 - same here? ( except are they bigger? im seeing 256 and 512 in the part numbers)
29F040 - monster chip that will take 16 bins (actually more, but the switching device cant address more then 16)
zif sockets:
I could use
G1 and the S2 or S4
G3 and the S2, S4, or more appropriately the S3 (taking into account you could use the big chip with the S3)
Questions:
1: can I use say: a 29C256 chip with the G3 switching adapter and the big S3 zif?
2: do the add on ZIF sockets fit inside the ecm cover? do I need one?
3: what are the differences between the 29C256 and 27SF512 chips ?
4: would a device like the autoprom lock into the ZIF or would one remove the ZIF?
5: 27C128 is our stock chip?
ItsMyTy
Life is beter at 25 PSI
well, i can't answer much but i can tell ya the add on ZIF sockets won't let you put the ecm cover on. so i don't use a ZIF with my G1 moates adapter and 29c256. however, if you are doing a lot of burning and swapping chips a ZIF is great, keeps you from bending the pins taking the chips in and out. then when you get the tuning dialed in and burn the final chip, take the ZIF out and you can put the cover back on the ECM.
atc82
so the major advantage of using the ZIF socket is for quick and safe removal of the chip from the adapter? any other reasons you would want to use a ZIF socket?
one more question I want to add to the ones that Ian already asked... On the Moates page, there is a device called "FlashNBurn" and it says that its a USB-Based Chip Reader / Programmer for $75. This is cheaper than most chip burners I have seen and was wondering if anyone had any experience with it?
Yeah, that the main reason, but trust me if your doing chip burning it is so worth not have to worry about pins getting bent. I think my cover may fit with the ZIF socket, but I never tried. When I am using the socket I am alway tuning mode (ECM hanging down or in the glove box) so I never bother. I have since purchased a Romulator, so I obviously won't be able to fit it with the cover on.
Re: questions about moates stuff
SyTyArchives said:
chips:
Yes we have a 27c128 for stock. We can use a 27c256 as well. The 27 indicates UV eraseable, the 29 is Electonically erasable. The 128, 256 is the size. 128 are pretty hard to find nowaday and you just double up or offet the bin by 4000h to fit it on a 256 chip. Our bins are 16K, alot of bins are 32K and some last chips gm used before getting rid of Memcal were 64K (27sf512)
