Quick question about alky/meth pumps
s10blaza
BOOSTED
I've been looking at all the kits online and its seriously nothing I can't get my hands on through work, for example I have the hobbs adjustable pressure switches in stock, I can get brand new water reservoirs etc...
What I'm wondering is what's stopping me from using a high pressure fuel injection pump for the methanol? I have a brand new inline fuel pump just laying around, part no. E2000 that's used as the secondary high pressure pump for the early 90s fords.
I found some specs on it.
Airtex E2000
Minimum Current: 12 Volts
Operating Pressure: 72.5 PSI (5 Bar)
Minimum Flow @ Outlet: 43.5 GPH (165 LPH)
Fuel Pump Location: In-Line
Just curious?
MRKING
New Parts for Old Trucks
Re: Quick question about alky/meth pumps
Unless the pump is made especially for meth/alky , your not going to want to use it . It will just corrode and break down otherwise .
TYTILIDIE
METH HEAD
For one, they use a lot more pressure than that. They also may not be able to handle the meth internally. I'd just buy a kit if I were you and worry about it.
nallj92
http://www.northerntool.com/shop/tools/product_9414_9414
This shurflo is similar to the ones alky kits come with. 1.8gpm at 60psi. the key is using a viton seal so they last. I think julio also does some special modifications to his pumps, but these are the basic specs.
I have been running this same northerntools, shurflo for 4 years. 100% meth. just dont let it sit over winter full of meth drain/wash out with water.
The old SMC kit used a normal in tank fuel pump. Corrosion is the biggie here.
As far as hobbs switch to turn it on/off that has been done many times, problem is its on/off. When progressive controllers first came out the hobbs switch deal was basically obsolete.
