Radiator mounting/water pump ?'s
hardtailcfl
Ok so these are probably dumb question(s) but my truck's radiator/electric fan was fairly cobbled together and I'm looking to replace it.
1) At rockauto.com they sell "Spectra Premium" radiators for around $115 - are they any good? direct replacement?
2) When I removed my old radiator there was NOTHING securing the bottom of it to the core support. Are there rubber mounting pads? Or I see a few holes in the core support...are there supposed to be pegs of some sort on the bottom of the radiator?
3) Will RPM's electric fan kit work with these radiators? It says designed for stock style radiators.....just want to verify.
4) Also on rockauto they have several water pumps. Are they any good. I know the aluminum edelbrock is the way to go but curious about the cast iron ones. Anything better about the aluminum ones besides flow/weight??
4C FED
Absolutum Dominium
Re: Radiator mounting/water pump ?'s
Whatever you get, make sure it is the 1.25" core not the 1" core.
The fan shroud secures the rad to the core support. The rubber bumpers just aloow a little movement.
The bottom core support should have two rubber supports at each side that support the core at each end at the tanks. Hope that made sense.
hardtailcfl
Thanks for the replies guys. I kinda figured there should be some kind of rubber pad down there guess they were just missing on my truck. The other thing I found odd is that on RPM's website the radiator they picture has what appear to be "pegs" at the bottom of the radiator. No one else shows this kind of radiator for a jimmy/typhoon??? Any ideas? Unless it's just a generic pic?
ghettosled
SYTY SUPERSTORE
generic pic, but some do come with pegs. In that case you can cut them off with a hacksaw. Also the radiators we sell do not have provisions for the heater core which aids in fabricating an air intake for your larger turbo. If you have an edelbrock water pump you can run one of the heater core lines off the 1/2" npt fitting.
