bdubb said:looks like they say NGK UR-5 Vpower. what was so hard to read about that?
Yeah, I checked them out on http://www.gnttype.org/techarea/engine/plugs.html. Found my fuel pressure was 58 with line plugged. How? Dunno. Haven't checked it in a while. My afr's were 14.7 at idle and 11.8-12.0 during a run with 20psi of boost and 112 octane. Spark advance was 23 @ idle and around 17 during a run, spark retard there were three spikes from 2.0 -5.8. Checked the iginition system and put in a fresh set of plugs yesterday (NGK UR5 with gap at .028), adjusted the fuel pressure and will take some diacom readings today. The plugs pictured were gapped at .035.SyTyArchives said:from comparing them to examples given on the web... looks like they are on the verge of 'carbon fouling' caused by retarded timing/rich mixture/bad ignition.
