TO be honest, this project is not difficult with the exception of removing the cat for the dp and the f'n turbo coolant line pluged into the block on the bottom...i have got to every bolt without issue, what I can't get is simply the dp to just slide out of the cat...i have sprayed it, pryed with screwdrivers, bashed with mallets, smashed with hammers, heated the thing up with torches, and even punched it once with no results.
I will likely go the cutting torch or sawzall way.
Its pathetic, and thinks its going to win this war, but it has no clue that I have some nukes in my back pocket. And I will tell you this, the cat will pay with its life once its out, because I plan on thowing it down the street and running over it with my buddy truck...that is only the beginning!
