Re: Ring thickness
DO NOT use 1/16" top, 1/16" second , 3/16" oil rings. Those rings and the pistons that use them are designed for racing in quarter mile with high RPM bursts of speed and use full floating pins and Eagle rods. . They are low tension rings, have poor oil control at low RPM and will not last in a daily driver. The pistons designed to use those rings are a forged of low silicon aluminum alloy with a higher expansion rate which requires more cylinder wall clearance.
You should always use standard tension 5/64" top, 5/64" second and 3/16" oil ring sets and standard gaps. I used Speed Pro L2256F-.030" OS pistons (not turbocharged) , Speed Pro R9903-.030" OS standard tension rings. Gap checked at .018" top, .022" second, .025" oil and .0026" piston / wall skirt clearance. Those gaps are on the wide side of the standard gap of .016', .020" and .022" for higher RPM. File fitting ring gaps makes the rings progressively egg-shaped so it is best to use rings that fit your bores with the correct end gaps out of the box.
On occasions where economy is no concern, high-end engine builders who build high performance race engines may go through several sets of rings until they put a set together that fit the bores out of the box. Those engine builders bore and hone the cylinders using a block plate and fit the rings using a special fixture that positions the rings in the bores. Then they put a bright light under the fixture to see if any light can be seen between the rings and cylinder walls. .Some race engines even use two-ring pistons with a gas ported top ring. In those race engines, having less cylinder wall drag is more important than good oil control. .
