sean
for all you builders out there. i need to know what size rod's to get, 5.7 or 6.0 (i will be going oliver's) i'm trying to get 9:5:1. i know i have to cc the heads and etc. just wanted to know what size would be best to work with. this is my build 3.75 stroker crank, bowtie block 051, pontiac heads, nightdriver,s old cam, nightdriver's tt turbo's, rpm's sheetmetal intake (square one), rpm's oil pan, custom je piston's 4.100 bore. also what would be a good oil pump to run for street strip
