sy#945
Re: Roller rockers............yaaaayyyy
Yea this is turning into a runaway thred so back to what the thred was originally about. So pretty much 1.52 comp cam pro magnum full roller rockers should be fine with the stock press in studs so long as you are using the stock cam. Right? Now 1.52 may be fine but I have a set of 1.6 comp cams full roller rockers sitting at home I also have a stock cam will I run into problems with these as in pulling a rocker stud out or will I be fine?
