0-60N4
I guess it's about time I learned to do some tuning. I bet Brian Green and John Waller have been saying the same thing for a long time
I know basically nothing and have searched the forum on the pocket romulator. Sounds like this may be a good start for me. I have the PLCdevices wide band system and the Ultimate chip with 50# injectors. I am also using Diacom.
I was hoping someone could give me a quick 101 lesson in what the pocket romulator will do and what is required. Here are a few questions I have. Please excuse my ignorance in this field.
1. So the pocket romulator connects to the factory ecm and the ultimate chip, correct? And the romulator stays connected. Then I connect the romultor to my laptop and make changes to my current chip program(s).
2. Do I need additional software such as TunerCat or something else?
3. I guess the revised program stays in the romulator and can not be permanently moved to the chip.
4. I read the romulator has a battery back up and a separate power connection (9-24v) for use if you will not be using it for more than 12 hours. Does that mean you can connect it to your 12v system and keep the program saved?
5. What happens if you do loose power. Do you loose the program completely or can you save it somewhere and just reload it? And do the ECM just default back to the original program if you loose the romulator memory?
6. Do you loose the other functions of the Ultimate like security and valet?
Thanks for your help.
