Set timing/New dm run
WyoSyclone
Re: Set timing/New dm run
Mike said:
Could you send it to me also so i could save it and compare it when i get all my work done? Also, how far is your wastegate rod adjusted in on your stage 1?
Hi Mike, sending in a few minutes... I have 15 threads showing on my wastegate rod... giving me 14.5lbs of boost at 30% setting in Code59.
...Rob
Mike
...Rob
When you adjusted it, did you just pull the pin and take the rod off the elbow that way or did you take the whole elbow off without taking the rod off first? I tried doing it the first way, but i found it difficult to stretch the rod to meet the elbow. Does the elbow have to stay at a 90* angle or could i take out the screw and move it so it fits better? (sorry if this is a little confusing).
WyoSyclone
Sorry we've taken this thread off topic :oops:
Since I was installing my Stage1 to work with the factory cross pipe on the intake I had to reclock the turbo. If you look at the pics on my link page you'll see how I had to modify the acutator rod to realign with the wastegate elbow. To answer your question, I simply adjusted the link on the end of the wastegate acutator rod and pulled it till it would attach to the elbow... that diaphragm in the wastegate actuator is pretty stiff! Hope this helps.
...Rob
Flyin Ryan
hated cuz he drives fords
My rod would not budge so I took one of the vac lines off the diaphragm and hooked it up to the air compressor.. add a little air and bam the rod moved all I wanted it to
Mike
Thanks for the tip, i'll try that the next time i adjust it
