Finally got it to work after I did a restore on the ole laptop, still annoyng as hell. Anyway got to record some runs on the ultimate tonight. Unfortunately I haven't got it to where I can record runs while I am spraying the water/alky........should be up and running by the end of the weekend though.
I had some good runs tonight:
T1-17- erratic boost control but the o2 and knock were well under control. o2 stayed around 930 on WOT(for all runs) and knock stayed under 4*.
T2-17- tried this just for comparison for when after I start the spray. my knock went up but only when I was above 3400 rpm about to shift into 3rd, then it went off the charts, over 12.7. Did that twice and decided that is plenty for a comparison.
T1-20- once again, crazy boost contol. knock was still pretty good, one time had spike to 8.x* but mainly stayed below 5* even after I was already heatsoaked.
All of this was running on 92 octane, timing set at 0, and FP set to 50#'s. I am runnning the V7, and the drivablity is better than the stock chip, no doubt about it. Things look promising except for the boost control, not a big worry being as my PTE kit should be shipped tomorrow 8)
I FINALLY MIGHT BE ABLE TO OUTRUN TED
::brews::
