SeattleSy#1255
Category 5 Conservative
Question regarding the relay I am going to use for the SMC alki....
There are 4 terminals on this relay...12v in, 12v out, ground, and "on/off switch".........
12v in is for power in from battery
12v out is for power out to alki
ground is ground
what is the on/off terminal for...do i not use this and is this terminal used for the option of turning the relay on and off? I figure i don't use this because the alki can be turned on and off from the cab...is this correct?
Lastly, the capacitor---where is that put in line? I am figuring in the power out line between the relay and the alki control box correct?
I am just flat out stupid with electornics so spare me on this one...
TIA
ground is ground
TIA
