Syclone#2960
What ever it takes!!
The typhoon is throwing out white smoke at WOT. I don't see any smoke at start up or idle.
What could be causing this to happen?
The spark plug on the #2 is always covered with black oil when I remove it. The other plugs appear to be clean.
I notice when I take turns while driving the truck will stumble as if the oil in the intake valley is being sucked into the cylinder.
I'm in the process of changing out the intake gaskets to see if this was the problem.
Has anyone else on this board had this problem with the intake gaskets?
