Smoking problem!!
sy381
Hey guys, this problem has me stumped for some time now. i have had it to several people and have did several things to try to get this problem fixed and i have had no luck. when i am driving down the road there is no smoke, but if i pull up to a red light or stop for a few mins and let it idle and then hit the gas it puffs out a huge cloud of white-blue smoke. i had thought it was my new turbo because i had bent up fins from pieces breaking off my stock air box!! :evil: wont do that stupid shit again, that thing went into the trash!! so i put on another new turbo and still have the same problem. The motor in this truck is completly rebuilt. Antone have any ideas for me??
JoeLutz
if it smodes at idle and startup, probably worn valve guides or bad valve guide seals. were the heads reworked?
ABLITZ
Damn Yankee
i talked to him on aol im,and he said the compression is good.all cylinders are within 2% of each other
sy381
well guys heres what i have, it smokes very little the first time i start it that day, then after it warms up it gets worse and if i shut it off for a few mins then start it again its bad. the truck was to have the heads all redone, valve job and all. the compression is all good in the cyls. no blow by out the valve covers eather.
SY756
Has anyone done a "leak down" test on it yet? Sometimes a compression test wont tell all. I had good, well decent, compression on all cylinders but a leak down test showed #3 was bad. Sound like yours is having the same symtoms as mine did. No smoke when driving but alot of smoke at stop lights and idle. Come to find out the rings and lands on the piston were "crushed". That was 5 years ago but the as far as I can remember it sounds the same. I hope it isn't something that bad, but if you haven't tried a leak down test it might be a good idea. Good luck
Hu Ryde
Have you done a bike tire vac test? I found that my lower intake gasket to head was bad and that could cause smoke since it's in the valve cover area.
HTH
sy381
no i havent did a leak down test, i hope it isnt the rings but that will be the next place i look if i put new valve seals in it and it still smokes. the bottom end of this motor has only 1200 miles on it, i will be very upset at my engine builder if it is the rings.
syclone#2659
i had the same problem...what happend was there was a leak, and some antifreeze got into the oil, riuning parts......id go the cheap rout and not drive it til you get it checked out .wat i did was get a oil analysis done its like 20 bucks and it will tell you what metals are in the oil and if there is gas , antifreeze , watter in the oil, and we all know anyof those can cause major damage, mine was just rebuilt also , and the leak was on the lower intake, also check your throttle plates for antifreeze, that will tell you if you ic is bad. and if you do tear apart the motor, pressure test the block, heads and intakes, just to make sure.....good luck
sy381
did you have a lower intake gasket leaking?? when i pull out the dipstick there didnt look like there was any antifreeze or anything in the oil... or is there to little to notice on the stick?
sy381
I am out of ideas here, i was told to check my return line so i did, everything is good there, so then i went and decided to pull of the intake and check out the gaskets, everything looks good there too, so what should i do just go ahead and pull the heads off now and get the valve stem seals done and the heads checked. i am getting so pissed at this smokin problem. it sat at the guys house that built my motor for a month and he never touched it, he was to put the valve seals in, he never did,so i got mad and just brought the truck home and decided to do it myself. a few people have told me that there is to much smoke for valve seals but i dont really know what else it could be at this point. if anyone has any other ideas for me PLEASE let me know. i want my truck back. im ready to have some fun with it!!!
leroy
I'm going through the same thing. I have about 2000 miles on my engine now. Compression checks out perfect, but still haven't done a leakdown. I really think it's the rings. What kind did you use? I've heard moly rings can take a long time to seal. I'm still driving mine, though. I've had to run a lot less advance than I used to, though. I checked my turbo oil return line also. I pulled the plugs awhile back. All but #6 had oil on them.
Valve guide seals can be replaced without removing the heads.
Look at this as an opportunity to upgrade. :wink:
