so... about those spark plugs.
conlyn
well, in a flurry of doing new front brakes and fluid/filter changes...
it came to doing the caps/wires/plugs... which was pretty straight forward and not quite as hard as made out to be.. provided you yank the wheels off and have the swivle connection for a socket...
but when we yanked the first plug it had a bit of wear and was a nice red color on the inside, nothign but excess use on this one.
on the the next, it broke in half when we tried to remove it, reason i figure why was the cracks going through the ceramic on the inside of the plug.
the next plug also had a crack in it on the inside.
the next however was the shocker... it was finger tight and has massive setament on the outside ceramic(compression loss :rant: )... so it kinda freaked me out...
the other 2 were ok... look like just prolonged(way to long) normal use.
so i gapped them all to .40 and reinstalled (i hear both 35 and 45 so... i figured half way would be best)
it runs noticably much quicker from a roll, and well... i'm kinda suprised it didn't run like complete ass due to the loose plug... tommaro i'll run it on DM a few times to see if it helped the slight knock i've been seeing...
moronmechanic
Re: so... about those spark plugs.
The loose plug probably had lots of crap on it because it wasn't properly grounded at all times thus was skipping a beat now and again.
Also, the higher the boost, the tighter the gap.
-Chuck-
sytyguy
Moderated User
Which side was that plug on? I put those plugs in some time ago (prolly better than a year now), but it has had PLENTY of miles put on it since then. Not sure why it would just decide to start loosening up. As has been already stated, go for .032-.035 on the plugs and make sure to always use NGK UR6s (like I sold you @ Daytona). When maintained, your truck is one of the best running, high mileage trucks out there (Chris Nolke territory for you OGs).
I'm always prone to overtighten......hmmm.....maybe I am becoming more and more like BG.
Hood
conlyn
ok, i'm going to stick with this gap for now but i'll make sure to change it next time...
or should i really worry with yanking these?
really no excuse for me to have waited this long, but i put other things first...
i'm going to start changing atleast the plugs themself bimonthly or so...
and the loose one was the passenger side front cylinder.
oh yeah... every plug that was in it was gapped at .40 when i pulled them.
sytyguy
Moderated User
Reason for .040 on the old plugs was probably wear.....I remember gapping them myself @ .032. The NGKs have a pretty good life cycle for most of our trucks, so I would only change them every 6-10 months (with daily use) for optimum performance.
I wouldn't worry with pulling them if your gonna leave the boost around 14-16 psi. Wider gaps hurt when you increase pressure (more boost), have a weakening coil, etc....
Hood's :2cents:
