Syclone0565
CustomMulticades.com
* * * Buyer backed out - Back up for sale * * *
Pulled all this out to start Project Executioner. (See build thread in LSx section) Below is the motor and parts list. Has less than 1500 miles on everything. I have every single receipt also if you would like to see any of them. 90% was built and installed by RPM Motorsports. You can go to their site and under projects you can see Jeremy's Syclone. Nolan did the tune mail order. Nolan only tuned it up to 24psi. 32K+ easy in parts. Basically whats included is a complete pull out motor with everything still attached, Complete RPM A2A intercooled kit, Precision 72BB Turbo, Full SS exhaust all the way to the tail pipe tip, dual wal-bro intake pumps Tank included also, filters, harness, Factory computer with the tune still in it. Bolt it in and drive it. I will even throw in the custom Precision torque convertor ($1100) if you can use it. Its for a 4L80E. I will take $15K for everything. I will not split this package up. Need to re-coop some money for Project Executioner.
RPM Street Terror Motor (Oliver Rods, JE Extreme 9:1)(Check RPM site for more info)
RPM Complete Vortec Heads Package
ARP Head Studs
Cometic Head Gaskets
Comp Cams Pro-Magnum Lifters (CCA-875-1)
Comp Cams Pro-Magnum Pushrods
Comp Cams Pro-Magnum 1.6 Roller Tip Rockers
Comp Cams Camshaft (Custom Nolan Grind) & Tuned
Crane Poly Locks
PT72GTQ BB Turbo (Polished and Ceramic Coated)
RPM 1.625" SS Vortec Headers (2000F Coated)
Stage 8 STG-8951 Locking Header Bolts
QTP 3" Electric Exhaust Cutout
RPM 3" Downpipe (2000F Coated)
RPM 75# Fuel Injectors
RPM Billet Fuel Rails
RPM Custom Fuel Lines and Dual-Pump Assembly
RPM Sheetmetal Valve Covers
4" 90 Degree Intake Elbows
K&N 4" Conical Air Filter (RE-0870)
K&N Engine & Turbo Oil Filters
Moroso Aluminum PCV Catch Can
Tial 50mm BOV & Flange (white Spring)
B&M SFI 29.1 168-Tooth Flexplate
RPM Upper Intake Porting
RPM Powdercoat Intake Manifold
RPM Assemble Complete Motor
RPM Install Headers, Downpipe, Exhaust
RPM Redo Intercooler Piping, Install BOV Flange
RPM Fabricate Turbo Support
RPM Install Fuel Rails, Rockers, Poly Locks
RPM Install Valve Covers, Alternator, Fuel Lines
RPM Install Turbo Drain Line, PCV, Intake
Nolan ECM Driver Mod and Custom Tune
ATR 3" SS Exhaust
PowerMaster Chrome 200A Alternator (38203)
Painless HotShot Starter Relay (30202)
Painless 3-Circuit Fuse Block (70103)
Racetronix Dual Walbro Pump Wiring Harness
Walbro 255HP Fuel Pump (x2) already installed in factory tank (Included)
Detroit Turbo AFPR
Vacuum Distribution Block
GM MEMCAL (16164174)
GM Distributor-Coil Wire (12048976)
GM Oil Pressure Sender
GM Knock Sensor
GM IAC Valve (17112193)
GM PCV valves (8995910)
Tahoe Mini-Starter (6449S)
MSD Pro Billet Distributor (8367)
MSD Blaster Ignition Coil (8226)
Borg-Warner Select Cap & Rotor
Dynomax SS 3" Exhaust Band Clamps
RPM EGT Probe Kit (ATM-5244)
RPM A2A Intercooler - $1200
RPM Turbo Oil Filter Kit (K&N HP1008)
3" Custom Aluminum Intercooler Tubing
Braided Hose and AN/NPT Fittings
RPM 3" Catalytic Converter
RPM Brake Booster Hose
RPM EGR Blockoff Plate
Accel 9000 Ceramic wire set
ITS IC-TB Transition Hose
ITS Minigate 38mm Wastegate
Thermo-Tec Exhaust Wrap, Spray Coating
DEI Fire Tape + Heat Wrap
Razor Progressive Alky Injection System
PLX Devices R-500 WBO2 Computer
Edelbrock Polished Alum. Water Pump (8891)
Billet Specialties T-Stat Housing (BSP-90420)
Throttle Body Plate (Intercooled)
Throttle Body Bored 52mm, New Seals, Air Foil
DEI Fiberglass Plug Wire Sleeves (DEI-010502)
NGK TR6 Plugs (4177) Gapped @ .025"
March Billet Aluminum Pulleys
Spectre Magnabraid II Engine Dress-Up Kit (SPE-7498)
ARP 12-Point Polished Stainless Engine Bolts
Hypertech 160F Thermostat
ARP Head Studs
Crane Poly Locks
ATR 3" SS Exhaust
Detroit Turbo AFPR
GM Knock Sensor
