Some AutoX footage
SYO237
SyTy Registry
Footage taken from Shindig 2010.
This was a fast course set up with SyTy in mind. Other than the first 2 turns, the course was had minimal hard brake zones so it was easy to really get up and go. Video was taken with a GoPro Cam
Viewpoint from Ian Turgeon's (SyTyArchives) windsheild
Same course, Jonathan Pope from headlight viewpoint
sytyguy
Moderated User
Re: Some AutoX footage
Also, for those thinking that the course looks too fast to really gain much with subsequent runs, remember that Adam shaved off like 10 seconds from his 1st run to his 4th (IIRC). So, even on "not-very-technical" courses, you can still gain tremendous amounts.
And he still had another 1-2 sec. in it.
SYO237
SyTy Registry
Yep, I think I took off 9 seconds...granted run #1 was just a feeler to go around the course so it was purposely slow (plus I had Lee with me as a ride-a-long so he could see the course). I have 2 vids of my truck, but they arent worth showing due to thats when I started having the trans issues and let off and cruised through the course to get off the track safely.
I lost the most time in the first 2 corners and then on the back slalom where I could have grown bigger nuts and pushed it even faster. Unfortunately, my trans breaking stopped me from continuing.
From Mark's vid, you can see I just couldnt get the timing right for the first corner with speed/braking. I was on the brakes hard and trying to throw the ass of the truck around to get into turn 2 without going into the cones. TONS of oversteer, so my exits out of the turns were sloppy....you can hear where I get out of throttle and jump back in after I get out of turn 2.
SYO237
SyTy Registry
Ian actually did it on his truck messing around going to the restaurant from the hotel. Its a cool angle. Between driving, working and moving the cam all around from truck to truck at the event, I guess it just didnt get done.
I plan to do more local AutoX events, so I'm sure I'll get some side action footy
BigBadSmoosh
You should have been there. :rotf:
[/being.a.dick]
Touche'
yeah would have been cool especially on pope's truck
it will actually help the owner of the truck figure out how stiff their suspension is.. front and rear.. I'd even suggest multiple angles to watch the front and back to see which corner is weak and is pushing the truck through the turns.
sounds good.. the gopro takes some nice video, pretty damn impressive.. i just felt like it was too damn small for handheld action.. mounted to something it is perfect. :tup:
SYO237
SyTy Registry
Im surprised you dont have one for scuba. They make multiple kinds of mounts...chest, head, wrist, helmet.
The stuff we didnt wasnt even in HD either. I need to get a bigger SD card and I'll do some HD footy. What you see on youtube is compressed too, its even better quality when you view the original.
BigBadSmoosh
I do have one for scuba.. but mounting it on my body would be a mistake as i move ALOT while diving, so it wouldn't be all that stable. The best spot would probably be on the tank and that would give a weird angle..
I use my point and shoot camera in an underwater case while diving, video comes out pretty damn good..
http://www.youtube.com/watch?v=mNFLtxenW_g
you can see how hard it is to hold a camera still with current, sharks, and while diving and in this video i was laying on the bottom of the ocean :D
