Some Help with DataMaster Please.
Bill Z
I finally got a copy of DataMaster. Loaded it up on my laptop, built my cable from the circuit everyone points to. I even got the thing to work and displays stuff on my laptop.
What I want to know is: Is there a way to set up DataMaster so it starts monitoring your engine when the program starts (Of corse with the cable all plugged in)?
Right now I have to go to 'File' and select Record from the drop down. Get the message about not being registered and only having x records left. Then I have to turn off the recorder and turn the monitor.
All of this seems like a hassle.
Is there a way to have it monitor when the program starts?
I left an e-mail for TTSPowerSystems but they must be on vacation (or something) because they don't return e-mail very prompt.
Any help out there?
odium
1BADGMC
Re: Some Help with DataMaster Please.
Just one option:
There are macro programs out there that record keystrokes and mouse movements that you could use to do this. I haven't used one of these programs since UO, but you can find them at www.download.com or some other shareware website.
You use the program to record you double clicking Datamaster.exe, clicking file, save as, file name, etc. and then all you have to do is press CTRL+R or whatever function you set it to to perform the task automatically.
kwick6
Any help out there?
Did you just do the free trial download off of the TTS website?
If you need to buy the license , contact me and I can get you setup if your having trouble getting a reply from TTS. I deal with Andrew from AKM Cables, and either him or I can get you registered. As soon as you enter the authorization number , you will not get the x number of recordings popup anymore.
thanks,
supersports10
Ok So How Do You Get Datamaster To Start Displaying???
Mine Just Sits There Blank, But Ive Never Done Anything To It, You Have To Go Into File????
Help!!!
Bill Z
You have to take the ‘Record ALDL Data’ option from the drop down from 'File' (at the top left of the window). Then you have to stop the recording (Recording starts automatically) and test your com port (notice the button ‘Test Com’). If your com port isn't working, you will have to select one that is. To do that you have to select "Setup" in the Serial Data Acquisition window. From that dropdown menu, select ‘Com Port’. It should give you a list of com ports it sees. Select one. Now try test com port again. It should work. Now try the 'Monitor' button. It should start up.
If it doesn't you may have to disable the hand shake. To do that you have to select the 'Options’ in the Serial Data Acquisition window. Take the 'Advanced' option from the dropdown and then you will see the ‘Disable CCM Handshake’ option. Click it. Now go back and try the 'Monitor' button again.
If that doesn't work, put the error message up on the board here and we will try to help you.
supersports10
ok so i got it to work, on com 4, tested the connection, and it says... system passed, unknown aldl data recieved, this may be an unsupported pcm type.:(
turned the handshake on and off like 10 times, still no workie:rant: :rant:
ive tried three different datamaster versions,
tt for the sy/ty
e 6 for the 93 cpi
and e 85 for the tbi
still no dice!!!!!! this sucks!!!!
so now what??????
Bill Z
It could be that you downloaded the wrong version of DataMaster from the TTS site. There is a special version just for the Typhoon and Syclones. If you did get the correct version, then you may have connected your adaptor wrong to your ECM connector under the dash. Did you get any instructions with your ALDL cable?
supersports10
im trying to get it to work on my 92 jimmy, not my sy, but it still should work right????
Bill Z
If you downloaded the Datamaster for a 92 S15. Remember the ECM for a Typhoon is diffrent than the one for the S15.
Quickstop [UK]
Combating adversyty.
I get the message:
The ALDL connection is working but is receiving unknown Data. It could be that the PCM is of an unsupported type.
Wrong ECM I am thinking?
TYTILIDIE
METH HEAD
Your first problem may be that you guys arent using COM 1. If you read the entire DM manual it tells you everything you need to know about how to use it except for how to diagnose problems. There is a special section for SYTY's in there and adjusting the serial timing and a few other things. Make sure you guys read that manual or youll never make it. It can be boring to read but well worth it.
TYTILIDIE
METH HEAD
Oh yeah, depending on what kind of cable you guys got, if you made your own or had someone make you one where you plug the wires into the ALDL port, you can get odd data if the wires are in backwards. I hook up to a few stock trucks here and there and sometimes plug the wires in wrong. Some will will read crap data and others will say no PCM.
