what spark plugs do you guys recommend for a stock syclone and what gap to place them in
E elorejas Member Jul 9, 2011 #1 what spark plugs do you guys recommend for a stock syclone and what gap to place them in
E elorejas Member Jul 9, 2011 #4 Re: spark plugs is there anything in specific that i should do to these trucks when doing the tune-up
blacktyaffair Donating Member Jul 9, 2011 #5 Re: spark plugs Verify TDC on the balancer while the plugs are out and replace the vacuum lines!
E elorejas Member Jul 9, 2011 #6 Re: spark plugs blacktyaffair said: Verify TDC on the balancer while the plugs are out and replace the vacuum lines! Click to expand... already replaced the vacuum lines for the ones from sportmachines and will check the tdc as well since im going to swap the distributor cap and rotor
