Speed pro -Fast reference angle
nightdiver
Just got the Fast and fired up the truck
i am in the initial set up and i would like to ask what do you have for cranksaft reference angle ?
Should i live it at 6* ??????
I got a plug and play harness
RAACCR
The reference angle indicates the static advance you've got dialed into your distributor. (You cannot input a value of zero, so if your distributor is at zero, the closest you can get is entering 1 degree as the reference angle.) I'd recommend setting the distributor around 10 degrees advanced. The quick & easy method is to: 1) Set the reference angle in SpeedPro to 10 degrees. 2) Hook up a digital timing light & start the engine. 3) Twist the distributor until the advance on the SpeedPro dashboard equals the reading on your timing light.
HTH,
Rob
nightdiver
Thats what i was thinking of but i had to ask before i do anything
For now its 2* but ill get it to 10*
Thanks
