Stange IAC issue
TYTILIDIE
METH HEAD
I noticed when I was doing my harness last winter that the clip to my IAC connector was broken. I actually noticed this a few years ago:oops: So yesterday I went to replace the housing. Well, as it turned out, the stock pin did not fit in to the new housing:rant: So I put it back in the stock housing and simply plugged it back in. Ever since then, I have had a high idle. Real high! About 1500 in park. 1100 in Drive. So today I swapped the whole connector out for the new pig tail. I hooked everything up exactly like it was. Still, high idle. For shits and giggles, I unplugged the connector and guess what, my idle went back to normal:roll: Anyone have any clues to what may be happening here?
TYTILIDIE
METH HEAD
Re: Stange IAC issue
FWIW, on DM my IAC position was at 6 at idle and under load about 161 then went to about 40 under normal driving.
Aeroking
e.i.
the IAC position should hover in the 40-50 region at idle. Have you tried pulling the ECM fuse for a few seconds, then putting it back in. After, when you first start the truck up, you should hear the IAC screw adjusting itself for the idle. If this doesnt help, then air might be getting into the intake somehow (throttleblades a little open, or maybe a vac leak).
TYTILIDIE
METH HEAD
Yes I actually just got back in from trying that a few minutes after I posted. No go. Maybe I need to just take the TB off and see what its looking like in there. I remember my old logs being right around 36 at idle. I can't remember for the life of me, is 0 closed and 255 open or is it the other way around?
TYTILIDIE
METH HEAD
I replaced the IAC motor with one I had laying around. I cleared the codes (there was also a 22 and 43 but assumed it was some kind of glitch since nothing "happened") and fired it up and it ran great for a few hours of driving. As I was nearing my house, CEL came back on now my idle is back up, and have 35 and 43 again. I am wondering if I don't have a bad ECM.
TYTILIDIE
METH HEAD
I just did another run and noticed that it says I am going 1-5 miles an hour when I am not even moving.
Aeroking
e.i.
you mentioned the clip on the IAC connector was broken off. The connector is square, is there a chance that the connector is on the IAC wrong?
TYTILIDIE
METH HEAD
When I had the harness apart that was one circuit(s) that I left alone. I only messed with things I deleted or extended. Something is still off, I pulled fuses and cleared codes and drove to Denver and back. Truck seemed to idle fine for the majority of my trip. I got back in to town and it started idling high again. I am going to re-check the wiring tomorrow, also will play with the set screw, see if I can get the IAC counts to the 40 range. Haven't had another CEL though. When the idle went high again, it was to 900 opposed to the 11-1200 it was before. I like my idle at a nice peaceful 650:lol:
NecroWolf
lost marbles member
i had yhis issue when i first started my ty after my engine and ecm swap to fast xfi, turned out the wiring was off on the iac connection.
