Start Up Issue (Not Puple Wire Related)
SeattleSy#1255
Category 5 Conservative
Here is the deal. Truck as been sitting for about 5 months. I put some good gas in it. When i got back, I needed to put the AFPR back on.
The problem is that the truck won't start. When I lift 5 months ago...it was running, come back, and now doesn't run. All TB plug in's are plugged in. The chip is in and properly seated.
What it does is sputter just for a second. It actually never gets going and dies, but it does fire for a second. It is maintaining fuel pressure via a gauge.
It somewhat acts like it would if you have plug wires crossed or the timing was way off...however it can't be any of those because nothing has been touched with that and I have checked.
It will fire real quick, but never really get started (sort of like it caughs)then just continue to crank over with nothing. After checking the FP, chip, the ignition system, and all plugs...i don't know what else to do.
Note: My starter click deal has gotten worse. I don't see how this would be related, but maybe it is. Like I said, when it doesn't "click click" and makes a connection, it caughs for a second and then nothing but a crank.
Thanks for your help.
cloneman315
Re: Start Up Issue (Not Puple Wire Related)
what chip is in it?when we first did my chip when the truck sat especially if it was real cold were it was it did the same thing,didnt have enough fuel in the start up ,might be that i duuno
SeattleSy#1255
well, its a custom 3 bar with 3 bar map....it has always ran on that....doesnt' run with stock chip and 2 bar either...so that is elimanated.
not sure what you mean quick storm about oil pressure switch fuel pump?
fuel pump is working find....not only can i hear it ....i verify FP at the fuel rails.
SY2932
Administrator
My money is on the ignition module part number 1048-2827. Mine went out after my truck was down for a period on time. It started once an then immediately died, never could get it started again until after I replaced the ignition module. However the fact that you are experiencing "purple wire syndrome" symptoms with a COLD motor makes me think that you have a loose/bad connection somewhere so, rule that out too. You will be able to see what the connections on the starter look like through the wheel well on the passenger side of the truck.
kentuc
First things first.Take your battery cables off and clean them.If that don`t help change the module.
Bill Z
Checking stuff is cheaper than buying stuff.
The first things to check are the vacuum lines. Sometimes they split just sitting there. Poor vacuum lines equal wrong air/fuel mixture. Check if any of the spark plugs are firing. If you are getting any fire at all, then your ignition module is working. Check the fuel pressure and bleed some fuel off and smell it to see if it has gone bad (I doubt it but check anyway).
Good luck.
TYRODD
My ass. Look at it.
Im gonna say the module as well, those things are some goofy SOBs ;)
SeattleSy#1255
problem is solved........that eprom on the carrying board was put on backwards.
thanks for the help.
