Starter problem
TYTILIDIE
METH HEAD
Lately Ive been having trouble with my starter. It usually happens more when its really cold but lately its getting worse and worse. When you turn the key, the starter will sound like its reving but not catching the flywheel. Sometimes I have to try to start it like 3 or 4 times before it catches. Anyone else ever had this problem? Any help is appreciate.
Mike
jjorgensen52
NHSTE - I'm the only one!
Re: Starter problem
Had that on my boat... the starter wasn't engaging due to a corroded shaft... lubed it up and it works fine now
Sy229
Move with Purpose
Re: Starter problem
Perhaps a sticking/faulty starter solenoid. Next time you have the problem, give the solenoid a solid tap with a rubber hammer, then try to start it up. If this works with any consistency then you've likely found the culprit.
ItsMyTy
Life is beter at 25 PSI
Re: Starter problem
replace the starter
while you're in there check the flywheel and see if it's got a section of teeth worn down
