so far to date
plugs ur5
wires atr
cap rotor
pick up coil
ignition coil- sparking at night
o2
tps
iac
intake gasgets
lots of ether no vacume leaks
timed 0 deg
oil change
oil filter
fuel filter
compresion check 160 across
top end cleaner
supenten belt
air filter
waste gate adjustment
atr exhaust
fuel pressure 42 builds pressure 2-3 psi when shut off
still idleing rough.
start up idle goes up to 1200 after five seconds comes down starts to idle rough
very slight break up and disaperes when idle goes higher
low rpm surge
put the a/c on and it smooths out alot almost perfect.
ANY SUGESTONS?
if the piston is at the top 0 deg.
don't i want to fire the cylinder before it gets to the top on the compression stroke?
yesterday the check engine light came on a code 44 ?
I'm lost ????
plugs ur5
wires atr
cap rotor
pick up coil
o2
tps
iac
intake gasgets
timed 0 deg
oil change
oil filter
fuel filter
top end cleaner
supenten belt
air filter
atr exhaust
low rpm surge
ANY SUGESTONS?
I'm lost ????
