stock chip timing tables
Osmosis
I downloaded the stock code 58 bin and the timing tables are crazy. all over the place from rpm range of 3400 and below. at 3400 rpms I see one cell reading 16.8, then the next cell over I see 89.65 and then 00.0 on the next cell in inrease of map values. I noticed that the ultimate chip bins also have chaotic timing tables.
What gives with this chaotic timing tables???
sytyguy
Moderated User
Re: stock chip timing tables
I'm not seeing it. Our $58 burns are based off of BBZB bins which have a relatively clean F1. Earlier ones (even back to the first Sy bin) have slightly different values but nothing like what you describe. I have seen botched bins show these characteristics though.
Upload the bin and shoot me a link and I'll look at it. What software are you inspecting the bin with? If TP, make sure you're using the correct xdf.
sytyguy
Moderated User
BBZB F1 Table
This is obviously just the F1 table. A stock BBZB will have 2.11 added in F80, -1.74 across the board below ~10 psi in F3, etc...
Osmosis
I"m using tuner pro to look at the bin. I downloaded a file from moats.net library. That table looks nothing like the F1 table I have. I figured the XDF file was the problem, however, I"m using the XDF file for 7749 ecm from moats.net?
thank you for the table, explains a lot! Now I wonder what the ultimate chip bins really look like with the proper XDF file? Where would one find the proper XDF file for TP looking @ the stock chips?
Thank You! :tup:
Osmosis
I'm using that same XDF file & still I see nothing like what you posted when I look at the stock bin in TP with the code 58 XDF file. I did use a code 59 XDF file for version 1.5 and I can see the timing table clearly but it is in a 3 bar map format instead of a 2 bar. what gives??
I figured out I can some-what see the F1 table with TP V 1.5 so that is something;D
Now, can you please post a pic of the F30 fueling table as I can see the timing table is more normal by viewing it via TP 1.5 code 59XDF. The fuel table is still chaotic and all over the place from my view.
Thank you!
:tup:
You have a corrupt bin, or mismatched XDF vs Chip type. Anytime you see big changes like it is a clue.
something on your end isn't right no bin was ever released like that.
leadfoot
What units is the "MAP" in the table above? e.g. PSI, In Hg, mm hg, bar, Pa
