Re: Stock FPR ??
To answer your question, the stock regulator will keep up just fine with a 255. If you were running a pump capable of supporting say 800+ hp like a weldon 2035 then you would need a larger regulator and return line in order to keep your base FP down.
The benefit of the adjustable regulator is the base FP adjustment. You can make 600+hp on a stock regulator if you want, you just need to adjust the fuel map in the computer. It still rises 1:1 per pound of boost like the aftermarket.
Many people just replace the pump with a 255 1) b/c it is cheaper then a stock replacement and 2) adds fuel volume to an already undersized stock pump. You only need to change the regulator if you want to alter your fuel map.
