As per the Helm's syclone service manual supplement:
"Turbocharger inspection
Check the shaft for free rotation. Stiffness could indicate the presence of sludged oil, or coking from over heating. Push inward lightly on one of the shaft wheels while you turn it by hand and feel for any rubbing or binding. Do the same on the other side. The wheels should turn freely without contacting housing, backplate or shroud."
Some side to side play is normal. Being that the turbocharger rotates at 130.000 to 140,000 RPM's, it relies on a thin layer of synthetic oil around the bearings to keep everything working smoothly. HTH's
Mike Campbell
