studder problems
S
sy2214
Guest
I just started to tune my truck and on 10 lbs of boost under load i pick up a small studder around 4800 rpms, after the studder the truck pulls fine. looks to go lean around then. Tried to richen it up on the fuel map but problem persists. any ideas.
smeagol
Need more info. what is the buildup, what is the ECM, what ignition parts do you have ?
These trucks are bitchy about ignition, it is usually involved in 90% of the problems run into.
jwaller
Evil Genius/SyTy Guru
I would go beyond that BG.... in all my dealings with my own pair and many others I've worked on 95% of these trucks problems are ignition related in some way. be it plugs, wires, cap, rotor, pickup, module, coil...
Sy769
I want coil-on-plug :wink: I agree these ignitions are finicky
One question came to my mind. If the ignition is pooping at ~4800 wouldn't the truck go on the rich side?
S
sy2214
Guest
I had the pte 52 turbo downpipe. I just installed the mccoy stage 2 heads and intake manifolds. the computer is an accell dfi. I have the msd digital 6 plus the msd gm coil. I have atr brand new wires and ngk tr6 plugs. I am also at 5000 feet elevation. on the dyno the air fuel ratio goes lean about 1 point.
