Syclone #560 Blown Motor
WyoSyclone
Re: Syclone #560 Blown Motor
Yes its unfortunate. Thanks, I can not free this wastegate up no matter what I do... I may have to take heat to it. How did you handle your wastegate problem?
Thanks
Tony
I replaced the turbo with a Stage1 from RPM.... I'll rebuild the stocker and put it back in storage. Heat and PB blaster will probably be my tools for freeing the stock wastegate.
Tony Dipatri
As you know I just bought the truck. Someone in the forums actually worked on this truck before I bought it and said that the wastegate was okay when he inspected it.. I'm wondering if the linkage inside actually broke or is just rusted. I will look into the stage 1 and probably purchase it if I can identify it on the website
Thanks
Quickstop [UK]
Combating adversyty.
Normally the flapper seizes or the vacuum lines to the flapper age and break, or the boost solenoid is disconnected. The vacuum plunger might not be connected either. Lots of simple fixes! Sorry this happened :tdown:
Find out what it is before throwing a tonne of money at it. I also had a seized flapper. You can take it out and then mill it down I think.
Tony Dipatri
By the way. Just saw your truck. Its very nice......
johnboy89
Well I feel your pain I went thru something very similiar last year. The rubber elbow on the solenoid broke. If I had to do it all over again I would probably buy a shortblock already done as mentioned below.
If you do buy a used shortblock make sure you have it gone through before installing it, nothing worse than getting it in there only to find it needs to come out again.
I would plan on being down for a bit, I was hoping to get back up quick and was down for close to a year.
[/IMG]
Loeryder
another vote for using a known SyTy builder to source the entire short / long block over having soemone local who says they know the trucks motor but cant seem to spell it right...
Just my nickles worth.
Mike Hood / Tucker Auto parts
Campbell Automotive up in Canada
Sportmachines in the northeast
TurboTime over int he NC area
RPM on the left coast
are all good options.
best of luck getting it mobile again.
turbomatt
thats funny, i said the same thing when i saw it. snapped a picture this past summer when it was still in the hands of the previous owner. chrome camaro wheels on a syty FTL!!!
Tony Dipatri
I was going to call you a jerk for that comment but then I saw the wheels. I'm with you lol. Not a good look on a sy.:rotf:
I didnt have the truck long enough to change the rims....Blew up in the few days...The stock rims came with the purchase of the truck....:)
Tony Dipatri
[/IMG]
Thanks,
I am looking at the RPM Stock performance long block, all stock but better materials I guess. They have it listed at $5190.00 and this way I will know exactly whats in the block since I am hearing different opinions from different performance machine shops about what goes in the block. I will also need to buy a stage 1 turbo cause my wastegate was rusted closed. I rather get a new turbo
with a warranty.
Thanks
