syclone manifolds with a 1991 2wd chassis
Boosted Thrills
first of i did a search and read old posts for 2 hours and came up empty handed, i never found anything that sead yes they fit or no they wont
so will the stock turbo manifolds fit? how about the crossover?
thanks for any help
TurboTony
The manifolds and crossover will fit just fine but the stock downpipe won't.
The 2wd a-arms get int the way. You will need to custom fab a downpipe to fit.
Tony
sleepy
The manifolds and downpipe will fit, but a notch in the frame was necessary - I have an '88 2wd Blazer repowered with Typhoon engine. I think there is a difference in location of the engine mounts from blazer to pickup, but it is close...
Crazy J
yes, on 4wd's they're the same, but on 2wd's the blazers have the mounts higher on the frame.
TurboJunk
questionable
Ty Sy manifolds cross over pip and downpipe fit in a 2wd.... i just finished doing it in my truck . evrything matchs up perfctly motor mounts, wiring harness. The ONLY thing i see being a little tight is the intercooler on the top it hits the AC line in my truck. The stock downpipe gives you so much room for th starter and verything it fits like the came that way from th factory
ctadams21
I have a sy motor in my 90 s10 and the stock downpipe and oil pan fit in fine. The ac lines are a little close to the intercooler though.
CTA
bucwildbob
proud owner # 1662
this is what i am doing with mine as well, freshly built 4.3 and looking for manifolds, i have a pm to one guy but if anyone is looking to sell some in great condition for less than 275 id like to buy a set.. both manifolds and cross over
