temp sensor
Nasariobv
sorry
sorry
yes i needed the coolant temp sensor....thank u very much
sy106 killing rice rockets at will
tealty
I was looking today at my ty and noticed the intake coolant sensor and the head coolant sensor are different. Does anyone know why this is? If they were swapped, would it make a difference in readings?
thanks
Jordan
canadian
sy in progress
thought i remembered reading somewhere that one is for the idiot gauge on the panel and the other is for the ecm. different wiring for them.
jwaller
Evil Genius/SyTy Guru
yup thats right. I don't think you can switch them, I think the plugs are different. anywho the one in the head is for the dash, that other is for the ecm. the head sensor has a larger OD.
tealty
yes john you are correct....the connectors are indeed different. The previous owner of my ty put a new wiring connector for the sensor on the head. Well, he put the wiring connector made for the intake sensor, so the sensor on the head was "slightly modded" to accept the new connector. That's why i was wonder if the readings would differ b/c i have a spare intake coolant sensor that i put on the head to get rid of the modded (messed up) sensor that's already there. The threads were the same size and it worked. So, I guess we'll see if the readings are normal or not next time i fire up the beast.
later
jordan
