the syclone a knocking!!!
martygar8
syclone #1322
was wondering if the crank, can be taken out through the bottom without pulling the motor, or is it easier to take the motor out? this stinks:rant:, was about to take her to the track one of these weekends. dam!!!!!!!!!!!
Syclone#2960
What ever it takes!!
Re: the syclone a knocking!!!
Better to pull motor out IMHO,
Did you blow the motor or are you just picking up some knock?
1madgumby
pull it for sure !! pull the whole thaing apart to make sure it did not hurt it to bad.
martygar8
syclone #1322
the truck is running pretty good, just started a knocking only when you start it up, for about a second, and lost my boost, no boost at all, weird!
1madgumby
I have heard of this before & ended up being something dumb but can't remeber what it was. search the site for the post.
90stangGT
Cobra member
If it was crank related, it would likely get louder with rpm. Not sure why it you would lose boost. Even if something did happen to the crank (not major but just bearing noise), I would think the truck would still be capable of building boost.
1madgumby
turbo locked up. bearings shot in the turbo not spinning, will run, just no boost.
