So far... My check engine light never comes on, but datamaster reads a stored code in the ECM every time I turn the ignition back on after clearing it. I have taken the ECM fuse out and waited 1 minute a few times to try clearing it in hopes that it is false from doing the cap/rotor, but it keeps coming back.
Code 42:
EST (Electronic Spark Timing) - This code is when the circuit is grounded or open. A malfunctioning HEI module can cause this code.
I have multiple friends that have had the ignition module go out on them and they can't even start the car. Mine purrs like a kitten at idle and drives around alright other than the bad spark retard under boost (don't worry, I still haven't pushed this truck and haven't driven it without datamaster since I found it had problems). Does anybody have any insight as to what lets me drive around with a malfunctioning HEI unit?
A new one has been ordered, btw.
Search words:
check engine light
flashing flashes 42
error codes
Code 42:
Search words:
check engine light
flashing flashes 42
error codes
