SBNova
I know to set the timing at 0, with the ESC (tan) wire unplugged. I looked at my tab on the timing chain cover and I see a tab with a tube attached at the right, then to the left of that I have three "points" or two "vally's" depending on how you look at it. Do I line up the mark on the balancer with the center of the tube thing, or at one of the peaks ? I am guessing its the tube thing, or the "point" on the right (of the three). So far, it seems that my balancer has slipped, or my timing is just way off. I can see one mark about an inch to the right of the whole tab with the tan wire disconnected. I have read that there are two marks on the balancer and I cant find the other one. This would put my timing about 20 degrees retarded.
The funny thing is that I have numerous reciepts for work done to my truck at GM dealerships and my tan wire still had a factory appearing black papery-type tape over the disconnect holding it to the harness. It has never been apart to check the timing the right way! I truly think its too far advanced, because with my new fuel pump I just logged some data and saw 5 degrees of knock at 3k rpm/ 192kpa, and total (compensated) timing was only 7 degrees. Thats 12 total, with 5 being pulled. I dont think I should have knock at 12 degrees, with a semi-cool IAT of 120 F on a cool evening.
