Truck running bad again...
0260IN3
Engine Builder
Re: Truck running bad again...
Kybol said:
Did it again yesterday, seems to only do it when it is really hot out. Any ideas?
Change the coil. Even if that is not the problem it's a good upgrade.
If the coil is weak, it will act up when it's hot.
MSD 8226
willyson
trollin'
are you saying that the truck is sputtering at acceleration but not afterwards? it will run, quit and wont turn over again until it cools? try cleaning the intake manifold for the sputtering
turbojav
hey i work at a muffler shop try and remove it to look inside and see if you can see through it if you cant then its bad of course if you cant remove it drill a 3/8 size in front of converter. some people say check it with a gage but its not accurate so its best to look inide .and if it,s clogged up then you have a problem with possibly bad o2 sensor or may be to rich ...
