Truck wont start - need help!!
The Bronze
Re: Truck wont start - need help!!
my ty is doing the exact same think i have a friend that has a 93 camero his was doing the same think he told me today that there was a sensor for the ignition that fixed his issue any body heard of this ignition sensor ???
The ignition uses a stator housed in the distributor under the ignition module to identify cylinder position. The module uses that information to fire the coil, The module also translates the stator signal and sends a square wave out to the PCM indicating engine rpm. Depending upon engine speed (over/under 400rpm) it allows the computer to control timing or the module does itself (Bypass). If you have good spark at the right time, the stator is working okay. If you have no spark and no injector pulse then you have a bad stator, module, coil or related wiring. If you have spark but no injector pulse, then you can take the coil and stator out of the equation. The module can still not output the rpm information (Reference) if it is bad.
Richie Rich
Very interested in this issue as mine does the same thing. Any update to the solution?
alwayscode390
pppssssshhhhhtttttttttttt
Did you check your ECM?
Did you put starting fluid through the throttle body? ---
Richie Rich
Sorry to high jack this thread.
Yes both... I have fuel I have replaced the oil and sparkplugs due to flooding from trying. I have tested with a different ECM/Memcal/and Burnt chip. We did have spark as well. The fuel pressure is good. The ECM voltage checks out at the various different connection points. Here is what happened. I had the master cylinder replaced, added an external oil filter for my new turbo, new turbo, new turbo lines, and REMOVED OLD TURBO LINES... Not sure when removing the old turbo lines if that disconnected something or not. It fired up before any changes moved it out of one bay and into the other with the one with a rack. Made the changes and then had to disconnect the coil to keep it from starting so I could prime the new oil filter and line to the new turbo. Then reconnect the coil and then it wouldn't start....
