Truck wont start?!?
Kybol
Turned it off at lunch and now it wont start, I remember seeing something about a starter wire fix or something? It did the same thing last night, but started fine this morning. What do I do, I need to get home after work :rant:
SY756
Re: Truck wont start?!?
If it's just not turning over then it sounds like the purple starter wire might be the problem.
Kybol
When I went down to the truck after work yesterday it started rigt up. Went and bought some gas and it started up after that. When I got home I jacked it up and kinda just moved the purple wire around, and then it wouldn't start up after that. What exactly do I do with this wire to fix the problem? I am going to pull the starter tonight and make sure it isn't shot though.
VermontTy
Support Our Troops
Here you go...
http://www.syty.net/forums/showthread.php?t=26438
All you do in essence, is move the starter solenoid from the starter to the firewall or fender, and run the 'trigger' for the starter solenoid to the new solenoid.
Here's the simple breakdown of how to do it.
1) Remove the wires from the starter, and remove the starter (after disconnecting the battery!)
2) Take a block of copper, drill 2 holes in it and jumper the two lugs as shown in the above thread. This will make the starter engage as soon as the solenoid feed (large wire) gets 12V. If you don't have access to a block of copper, I have a spare that you'd need to grind and machine to fit.
3) Go to the parts store and get a length of battery cable with 'eye' ends on it; 3' is probably fine. Also get a "ford" style starter solenoid like pictured above, I used a Conrad F492.
4) Mount the solenoid somewhere; fender works, I did mine on the firewall right by the 12V junction block as pictured below.
5) Attach the battery cable that goes to the starter (the one you bought at the parts store; top red one in this picture) to one terminal, and the wire that used to go to the starter, to the other terminal (black one, mounted to lower terminal).
6) Reinstall the starter with only the one new battery cable installed. The purple wire does not attach to the starter anymore.
7) Finally attach the purple wire to the 'trigger' for the solenoid. Mine was the small post on the left; its hard to see.
8) Reattach battery and fire the bitch up.
Jimmy
Banned
How about this:
Disconnect the purple wire.Trace it to the loom above the brake booster.Cut it off and replace with 10 gauge wire.Hook it back up.
:rant: IMHO Having dealt with big truck starters over the years, although workable, I would disagree with this system. First you’re sending juice to the starter motor before, or at least as, the starter gear is being engaged. Bad for the starter/flywheel teeth because the starter gear is now turning as it engages the flywheel. If, and this is a big if, the starter itself is ok then the copper link is unnecessary and redundant. What you’re really doing here is trying to send full battery voltage to the starter solenoid. (The starter itself already has full voltage because of the bat cable attached to it.) So, change, replace, whatever the purple wire only. Using the key to activate a solenoid that, in turn, independently sends juice to the starter solenoid only is the “correct” fix. All the above of course assumes a fully charged "good" bat. :rant:
kentuc
The Ford solonoid also keeps the starter drive engaged on the flywheel just a bit too long after starting.
I just install a relay for the purple wire. Full 12v pulls in the original solonoid just fine.
