Re: tunning with alky
I run 11.2 when spraying 100% meth, but every engine is different. I agree that that is a tad rich.
Yah not sure how much boost you are running but I forgot to add when I dyno tuned, it was @ 25 PSI, that is w/crap 91 octane, if were to run 16-17 PSi, like the O.P. probably 11.2-11.5 range A/F ratio w/100% meth spraying.
But, depending on what octane gas you are using & what timing you are at it just varies so much, there is no one set A/F ratio that works perfect for every engine.
I remember Nolan would adjust the A/F ratio to 10.8, anything leaner on a pump gas engine, they would tend to detonate. This 10.8 A/F agrees w/the tuning I have done w/91 octane.
Also to add, the Alky kit I use is Julio's, ALKYcontrol, that is what Nolan was dyno tuning with also, probably makes a difference if you were using a different alky kit like snow, devils owns etc.
