Ty Boost Issues
RALLYT-WRX
Ok, I have been having some problems. I have been slowly giving my Typhoon a freshening up and trying to fix some gremlins along the way. The issue I have been having is when the typhoon starts building boost is simply does not go anywhere, it bascially feels like a normal 4.3L V-6. I can hear a audible boost leak at the rear of the engine and all of the vac. & PCV lines are tight and connected.
So far I have replaced all the upper and lower intake gaskets, TB gaskets, EGR Gasket, exhaust gaskets and the turbo is brand new (less than 100 miles on it).
So, does anybody else have any ideas of where else to look for boost leaks? Or any other idea of what may be causing theses issues?
Thanks for the help.
Matt
skwayb
NWSTP
Re: Ty Boost Issues
Sounds like your Throttle body to IC hose is letting boost out. It has been an on and off problem on mine for a long time since the front mount on my ATR IC broke. I would check that the clamps are on and tight. Make sure they are not crooked either.
