driving down the freeway, got into it a little bit and it just shut off. got it towed home and it has no spark. the previous owner put an msd digital 6al in it with an msd coil. naturally he hacked it. I tried another coil and module. I did the test with the msd box jumping out the purple and green wire and it sparked when I grounded a screwdriver off the coil wire. the coil isn't the plug and play msd ones it has 2 studs. the factory harness is cut and butt connected together. so it seems the msd box is giving a spark, coil and module were switched with no luck, ecm fuses are good. is there a way to bypass the msd box to rule that out with that coil in there? or do I need to get the correct coil and screw with the cut wires? thanks
