Ty wont start!!!
jbone
I went to start the truck this morning and ran for maybe ten seconds and then died. Now it wont start. It turns ovre but thats about it. I just cant figureout why it would run for a few secs but not start again. Im not very good at troubleshooting so any ideas??? I need to move it tonight before it start snowing and everything.
jbone
Re: Ty wont start!!!
ok ill try tomm. its really sh*ty weather right now. Just the other day I replaced the dist cap/rotor and it worked fine.
MikeRenz
not stock
well then i'd check your coil wire also..maybe you didn't have it seated and it popped off
It's a stretch but check the coil itself. I've seen them just quit.
jbone
awesome ill check all that next i dont think that its the fuel pump b/c i still get fuel pressure. and not too long ago i upgraded to the walbro 255. but il check any way. Thanks for the help guys. :tup:
jbone
Well I went to start it today just for shits and giggles and whata ya know!!! It started right up. :D IDK what happened but at least its running now. Im still getting the same screetching noise from the distributor that I was before I replaced the cap and rotor though, so do you think I should replace it?
Well I'd at least pull it and see what going on. New/rebuilt ones aren't that expensive.
BTW you say you're sill slow with that build. How slow are you? :)
sleepy
If you have a screeching noise from the distributor, you should fix that problem - Noise could be bushing in distributor being bad, the loose shaft can cause strange side effects. A new distributor is not a bad investment either, better spark distribution means better ignition.
jbone
I ran a 14.2 something at the track cant remember the mph. It was 80+ degrees w/ high humidity, bad track conditions, bad heat soak in engine bay, less than a 1/4 tank of gas, and Im not 100% sure but someone told me that the ecm limits boost when you start the truck but I have an ATR pitbull chip. Anyone know if thats true?? ( I didnt pay attention to the boost gauge). ANd I hadnt done any tune up
Not familiar with the pitbull chip but put some gas in the tank (1/2 or better), find some better conditions and I'll bet you can pull nearly a second off that. Course if you're like me it helps if you know how to launch consistently.:)
jbone
I can launch consistent at the street but the track was a diff story. I was distracted due to the fast light I didnt have enough time to stage. I didnt know at the time that I was starving the truck of fuel with less than a 1/4. My next plans are to have jwaller do a 57mm turbo upgrade, ultimate chip (if I can find one), and work out some cooling issues over the winter any other suggestions
jbone
Where can I get a new dist. ? I figure maybe I should upgrade while Im at it. Anyone have any preference,price, part #'s etc?? Will I stil be able to use the dist cap and rotor I just put in or black beauty wires or do I have to change all of that?
