Ultimate, alky, & tune RANT
gjp
another post whore
Re: Ultimate, alky, & tune RANT
My friend works at speedmerchant. He says he can get methanol. He is finding a price for me. He also sells up to 120 octane in 5 gal cans. I think after 110 it has lead in it though.
I got hailed on today in gilroy. Cold as hell for california. Nothing like working outside in the rain.
10secTy
Sy-Ty builder and Tuner
If you are going to pull the plugs put a set of NGK UR6IX gapped at 28.
Meth injection will really test your ignition system.
Also if you are spraying to much meth it will break up and look like knock to the ecm.
Nolan
live1053rulz
Nor Cal SyTy
I did the NGK UR6's gapped around .031ish. I have been having issues, but adjusted my wastegate actuator and it's running way better tonight. To much meth is definitely a bad thing. I've been playing around with turning the fuel down on Phils chip while turning the alky up a little bit. I got 100% meth. There's a place in San Leandro, I forget the name of it at the moment, but I got my meth there and my Dad buys all his race gas there. You have to buy at least 5 gals at a time, but I think at 5 gals, it was 2.76 or something a gallon, definitely not bad. Speed Merchant sells it for something like $35 for 5 gals. I'd suggest this place in San Leandro for the locals here. Let me know if you guys want the name of the place and address. I hope we can get several of us out to the track after it starts to dry up a little. Ohh, it hailed like a mother in Santa Clara today for awhile. God I hope it snows. I wanna go spin some awd donuts, I doubt we'd get much at all though.
James Thomas
"NO CLASS"
Yes the name address and phone number for the fuel supplier would be a BIG help! Denatured Alky here is $11.00 a gal. and unleaded race gas is not available at all. I need a supplier for unleaded and Meth in 5, 20 & 55 gal. off the west coast.
Thanks!
______________________
James Thomas
mrweelr
Don - I'm running UR6's at .032 gap with SLX denatured, but I'm still not satisfied with the inconsistent results I'm getting with the progressive alky setup. I'm running base FP ~40psi and use settings 4-6 on the Phil Long 50# chip. I noticed the truck runs leaner/richer, depending on the weather conditions (temp and humidity). Datalogging has shown that the alky does bring IAT temps down and reduces KR (if any), but I get that breakup issue at times too. Turning the gain down usually fixes this. After reading the feedback in this thread, I'm going to try a .030 gap and turn the boost up a little more. Between you, me, and Steven, there are three of us running the Razor kit on stock motor Sy's here in the Bay Area now. Hopefully, we can figure the alky tuning out by datalogging and comparing notes. Oh yeah, I have been trying to keep my AFR between 11.8 and 12.1; that seems to be where the truck feels the strongest.
10secTy
I have set up a bunch of cars and trucks with Razors meth kits.
#1 I run 100% methanol
#2 I run irudium plugs gaped 0.028-0.025 ( meth will test your ignition system)
Now tuning for meth. What I do is run the truck on C16 Dial in the air fuel ratio to 12-1or a tad leaner up to the highest boost level I will run. Once that is done I dump the race gas and fill up with 91.
Now I set up the meth to come on in the 2-3 psi range I spray enough so that I am in the 10.5 -1 air fuel ratio. This means your are spraying a full point and a half of meth on top of the gas. This is alot of meth but from what I have found it does not hurt power and your are better off to spray more than you need. The one thing you have to be carefull with is that if you go to rich with gas or meth it will break up and this will look like knock on datamaster.
We have full weight trucks here with just nitto drag radials on the rear that run 10.8's all day on 91 and meth injection with 24-25psi.
nolan
mrweelr
Thank you Nolan for sharing this information. Now that's what I call a useful reply! :tup:
Nolan & Jeremy and everyone else on this thread for that matter, THANKS.:tup: I had some PM's with Nolan as well, very helpful. Still getting some miss at the far end at WOT with alky on. (I say alky because I'm not yet on real meth but that will happen soon.) I'm thinking I've got ign issues causing the miss so getting everything as good as I can there while staying with the stock dist. following suggestions with plugs ect. I find it interesting that my trap speed has improved a couple mph, even with the miss, but not my ET's.
Thanks again...
gjp
another post whore
I hope you can git it running good. I am just sitting back waiting for you guys to figure this out so when I get mine I will have some help. I am having trouble tuning my truck with out alky. We all have to do a get together soon. Good luck.
live1053rulz
Nor Cal SyTy
Ohh man, I don't know if I ever got back to you guys on where to get 100% meth pretty cheap. The place is in San Lorenzo and it's called ERC (Engine Research Co.). I think it was like $16 for 5 gal. They'll only sell a minimum of 5 gallons, probably best to bring your own can, or they can sell you one. I think they're pretty easy to find online; Yahoo Yellow Pages or something.
