Ultimate Chip Troubles???
NeedaSY
Go Ahead N Go
I was parking my truck and went to push the button to change the setting from T115 to security and when i pressed it the button clicked but the screen didnt change and now its stuck on T115 just curious to know if someone has had tis problem before??? Or do i got to buy a new one. Cant press the other button either they both dont do anything but if you press both of them at the same time this message appears saying OPEN KEY???. I dont know what that is?? This sucks!!
Re: Ultimate Cip Troubles???
:2cents: Don't know what any of that means but try removing both ECM fuses to "reset" it, so-to-speak.:2cents:
ZavzTy547
Senior Member
Strange, Open mode should enable you to toggle threw the settings.
Sounds like your in Lock mode (or Lock Key). You need to know the security code in order to unlock it. I would pull the ecm fuse first and see if that resets it....
Ty1642
Like the other post noted, what you're describing is exactly the way the Ultimate acts when it's locked. Just in case you don't know, to lock or unlock it, you press both buttons at the same time. It will give you the message that you're seeing. You then enter the combination of button presses that unlocks (or locks) it. If you do it right it will then say 'locked' or 'unlocked'. When it is locked you can't change the setting. Normally what you do is put it in SEC mode and then lock it so someone who doesn't know the combination can't change it.
If you don't know the key combination to unlock it you might ask the previous owner. I don't think removing the ECM B fuse will unlock it.
