Re: Vacuum canister hose
You guys think too much. It is a simple system with multiple purposes.
When you go to the gas station with a plastic 5 gal can and fill it up for your lawn mower, you close the filler and put the vent cap on so you don't have spillage. On a nice warm summer day, when you get home, the 5 gal can has balooned and when you release the vent cap, you get a purge and the can goes back to proper size. Same thing happens in your gas tank. Gas fumes make pressure. The pressure (vapors) go to the purge tank (charcoal can). When the engine starts, the vacuum sucks out these vapors and burns them. Helps save the enviorenment.
The purge tank has limited capacity and obviously the tank cannot blow up due to excessive pressure. It will have to purge the excess vapors. Reason for charcoal.
The gas tank needs an air inlet as the gas level goes down. The aforementioned vent on the plastic 5 gal can, leave it closed and pour the fuel out. After 1/2 gallon, the flow slows and will eventually stop (as long as you have the can tipped up enough). The sides of the can cave in. Open the vent and the fuel flows again. Same deal for the gas tank. Need to let air in as fuel goes out. Take a 2 litre of soda pop. Tip it up and start chugging and watch the sides cave in. At the next SyTy event, have some one take a glass beer bottle and start chugging without ever releasing their lips or releasing air back into the bottle. I'll give cash money to anyone that can empty the bottle without letting air in before the liquid is empty.
If you fill your tank and top it off to the max and let it sit in 100 degree weather, the gas expands. You could end up with raw fuel in the evap tank in this situation. Gas mileage advocates claim the hot weather provides better fuel mileage as your 10 gallon purchace can expand to (insert mathematical formula here) leaving you with more than 10 gallons and better fuel mileage.
I used to race a high 9 second Chevelle (full weight 496" big block.). Took the vent system out of the car and left a non vented cap on the gas tank. Car would lay over in high gear. No matter how many jet sizes I went up, no change in mph. Thought the fuel pickup was starving. Went to put in more fuel and removed the cap and the tank popped. The tank was caving in. Put an old school vented cap on the tank, problem solved. Bam 130+ mph on the next run (after putting the jet size back to what it should have been).
Back to work. Have fun.
Let me know where to send the money to start a pot for the aforementioned beer chug from a glass bottle. Sounds like a good Saturday night event at the next Homecoming.
