I've notice most SyTy owners are using roller rockers. I put a set of 1.5 comp cams roller rockers in and now I have clearance issues. What alternatives do I have versus a custom sheet metal set of valve covers.
If you're having clearence issues,check the baffles on your valve covers.Comp magnum rockers are fairly loose on the valve and sometimes hit the baffles.Ask Mike King,he had the same problem.
Jack
i think the edelbrock covers have a touch more clearance. All the full body aluminum rockers hit, and all the roller tip rockers clear. It is a 50/50 with stainless full roller depending on the truck and the brand rocker being used.
