Valve seal ?
Sean Krupa
Moderator
Does anyone have a part number and where to purchase good valve seals? Also, any step by step installation would be appreciated.
Thank You
Richard Le
Re: Valve seal ?
I'm getting Felpro SS72876 valve seals installed on the exhaust valves. The kit came with both O rings and nylon "umbrella" seals. The factory only used O rings on the exhaust valves. Should I have the nylon seals installed also in addition to the O rings?
Richard Le
Re: Valve seal ?
My mechanic spoke to a Felpro tech and was suggested to use both the O-ring and the umbrella seal on each exhaust valve, so I will go with that suggestion.
